I just started getting this problem yesterday. So before yesterday everything functioned properly. Here are my symptoms.
(Running lights and brake lights off) Rear left turn flashes, and rear right turn flashes at the same time, only dimmer. Rear right turn works properly. Front left grille and fender turn flashes, and Front right grille turn flashes at the same time but dimmer. Front right fender does not flash at all. Front right grille flashes properly, but Front right fender still does not flash.
(Running lights on with and without brake applied)
Left and right rear turn flash properly. Front left grille and fender flash properly. Right Front grille flashes properly, but fender does not.
In a nutshell, both sides Front and rear flash with left turn signal but not the right. Front left fender running light and turn works, but right Front fender running lights only, no turn.
I'm at at loss right now. Going to start checking fuses, maybe unhook the battery to reset computer? Anything else I can check?
