Has anyone else had an issue with the engine oil cooler unit failing?
Green Jeep Freak
Australia
Mine failed at 87k, pumped all the engine oil into the cooling system
Ended up putting a 2nd hand engine in from a wrecked demo Wrangler
Looking to see if this is a common issue with the 3.6 petrol engines
The week this happened I was making calls to work out the option on what to do.
I heard nightmare stories about how many Wranglers were get engine rebuilds or replacement engines.
At least 5 including mine, all in Perth, WA Australia
Any symptoms before it failed?
Mine has a slight smoke at the canister location (passenger side) during hot summer times but I have been ignoring it.
Happened on my sisters Chrysler Town & Country minivan as well, which also uses the 3.6 Pentastar. Go figure!
Wow! Yes, but not like your failure. My '14 had the housing crack. I noticed it not long after I bought it. It was "certified used" so the dealer covered it. My symptoms were drips of oil around the bellhousing. Upon looking further (I used an inspection camera), I could see oil in the valley underneath. The dealer told me that the oil filter cap would get tightened too much and crack the housing, causing the issue. @Oscar-Mike I'd check the valley with a clean wooden dowel and see if any oil is pudding.
Needless to say, I've been very careful doing oil changes.
