Any answers appreciated! I have 2015 Jeep Wrangler Rubicon.
My fuel pump fuse keeps blowing. I put it in the shop and they said the fuel tank was not holding pressure so that ment the fuel pump was bad and that’s why the fuel pump fuse keeps blowing. So I got it home and changed the fuel pump out. It started up and would throttle. When I put it in drive and hit the gas the fuse blew. We changed the fuse.
Jeep in park pressing gas - good fuse.
Jeep in drive with ebrake pulled and throttling the gas - good fuse.
Jeep in reverse with ebrake pulled and throttling the gas - good fuse.
Jeep in drive just letting it roll naturally with no gas - good fuse.
Jeep in reverse just letting it roll naturally with no gas - good fuse.
Jeep in drive/reverse hitting the gas pedal- blown fuse.
We have checked the fuse, the relay, the wiring harnesses, the fuel pump is brand new and working correctly. I’ve been told it might be a “Fuse pump driver module” but when I look online I can’t find any information on it at all. I really don’t want to have it towed back to the shop again but I’ve hit a brick wall and I’m not sure any other options!
