Frustrated Jk
DMOinox
So Cal
Ok, I have a 2007 Jk 4 dr. Got the
P O codes so I replaced the canister, purge valve, pump and gasket. I even changed the gas cap. Now I am getting check engine light again the gas cap banner . Also,I just replaced the engine. Its a 3.8 from Jasper. What am I missing? Thank you
What Codes do you have?
Have you tried doing the battery reset after you replaced the parts?
New esim and gasket fixed my 07. Check the evap line that runs right on the side of the battery. It rubs there and can cause problems. Good luck
Reactions: Vman and mrjp
Write your reply...
