Front end wander
Howard R
wakefield NH
i have replaced the ball joints and the steering stabilizer.. my front end will seem to all of a sudden move Half a lane or more than it should from side to side.. my tires are not new but have decent tread.. my tiers and box look tight when someone is shaking the wheel.. have all 4 tires at 45 to 50 lbs pounds of air. 285/70R18 tires. even tried putting back tires on front.. no difference..
Are your front and rear tires the same condition? I had 315's on my Jeep when I bought it and the front tires were old and bad condition due to alignment. It used to wander and when I went to the stock tire and rim my problem went away.
Is the steering stock or does it have an aftermarket steering setup? Post some photos if you aren't sure.
Also, have you had the alignment checked? I'm curious to see what the caster numbers are.
