Front coil springs
TROY66/68
Still in Play
Lifetime Supporting Member
Muskoka ON
Lost a chunk from my base, guessing do to salt the last 14yrs. Ordered a pair from Amazon 81222. Noticed on invoice it says Sport with A/C. I do not have A/C. Looking underneath ???, is it going to make any difference. Are they just rated for the extra weight?
The coils are the same diameter for the JK's just different spring weights so the base should be the same. If the bases are heavier then without AC then your getting better ones then it was from the Factory.
