Evap leak video (need confirmation)
Threepointsix
New Jersey
Hi, all-
I've got a P0456 code so I purchased a smoke machine and did a smoke test up top of the engine and then below. Ran smoke through a hose thats attached to the charcoal canister and noted smoke coming up through what I believe is the Vapor Canister Filter. Which is located next to the fuel filler hose. I Read on this forum (I believe) that smoke coming from this is normal? But my video is showing a lot of smoke.
Is this in fact normal?
Any insight would be greatly appreciated. Thanks in advance.
Please see attached video:
Reactions: Artisanau
UPDATE:
Don't know how this cleared my code but I started using Exxon/Mobile, BP and Shell regular fuel and the light went off after a few drives. Knock on wood, it came back one time for maybe 10 miles and hasn't returned. I also now shut off my Jeep when I gas up. Another interesting thing is pinging noise at low RPM's is gone. Best with Exxon/Mobile. Would never believe it if someone told me the same, but it's true! Im sold on not doing Delta, Fuel 1, and the like.
I don't think I have ever left my vehicle running while filling up in all my years of driving. With modern vehicles it's a no brainer, imo, with the EVAP monitor, which will accumulate leak events over time.
I was also told to never overfill the gas tank either. When the pump shuts off that's how I end it. I know lots of people who will squeeze a few more times to round up the price but overfilling can cause a P0456 code too.
Reactions: WSS
UPDATE:
Could have been your gas cap, not sure which code that throws
Reactions: JeepJeezy
I fixed my p0456 this morning. Yesterday I bought a evap canister, evap thing next to battery and the leak detector pump. I installed everything but the leak detector pump last night. Amazon delivered the pump this am. There was definitely something wrong with the old one. It rattled when shook, the new one did not rattle.
My gas cap,p0456 trouble started at elevation when my wife topped it off. I never really gave it any thought. It is possible that a small amount of gas made its way to the detector pump.
P0456 and it just popped back up couple days ago.
Was thinking gas cap. Comes and goes (cycles) and for full transparency, I glued my gas cap and perm stopped it from clicking. Was a suggestion I saw on Youtube which seemed to work and helped for a while to clear the code. Seal is probably just shot. But same time, could be the purge valve. Though, I disconnected and tested it. Maybe that or the module attached to the charcoal canister is intermittent. What a pain in the nut!
Maybe your attempt to remove the electric plug helped make the contact better. If you can take it off with the plug on, shake it back and forth, if you can hear something shaking inside, that is your likely culprit.
Reactions: Threepointsix
Going to try this. Just wish I knew how to remove the damn electrical connection. EDIT: I see you said I can keep it plugged in. Wasn't sure I was able to do that, so I will try. And for the record the CEL is back on again. Its now been cycling every refuel. Ive yet to fill my tank to the top, though. I just add 20 bucks every couple days.
that plug is a little tough to get apart. I think the location has a lot to do with it.
CEL RESOLVED- Thankfully, it's been a couple of weeks now and my small leak (P0456) code has disappeared. If it wasn't the replacement hose that goes from the purge valve to the air intake that I replaced ($45!!) then it was reversing the seal around the gas cap and lubricating it that fixed the CEL. But I only figured that out after running my code reader again and realizing that original code disappeared and I had a new one! That was a P0113. So I checked the wire connection for the AIT sensor and bingo, that was loose because the security tab had cracked. So I created two 'collars' with small zip ties tied around both wires and used a larger zip tie to pull the two together. That resolved the P0113.
So far so good. Probably only a matter of time till some other petty BS comes up. But hopefully not! 🫢
