Got a 2012 Wrangler 2dr. Found a damaged shaft seal on the shaft from transfer case to front axle. It's the seal on the tease end. Is this task as easy as it looks? It looks like I take several bolts out and it separates.
Yes it is lifted. Was already when I got it. Not exactly sure how much but from what I have read about gauging the lift I believe I'm at least 4". From what I can tell the shafts were replaced (I think). Not sure if that is the part or not in the url. Looks like it could be. The damaged seal is at the transfer case where the shaft goes to front axle. Checked the tranny fluid last night and it is low. TC is prolly low to. Think I'm gonna go ahead and go total fluid change all around. Tune up also.
				 wranglerjkforum.net
					wranglerjkforum.net
				I'll have to check into that. My thinking is, wouldn't the angle be the same either way? The shaft will still have to installed into the same points of the TC and front axle. I'm not seeing how the angle would change.
				 www.adamsdriveshaftoffroad.com
				Just got off work. I'll send better pics of the shaft.It's going to have a different type of joint at the T-case.
Sorry man. The lil lady had me busy . If these don't are not good enough let me know what u need.View attachment 119454
Yea, I took a screenshot of it. I noticed they also had a complete shaft that wasn't a bad price. So it's not a smart idea to drive it right now then, is it? It has fluid in the tranny but it is low. Prolly low in TC to I'm guessing.The part that I linked to you in my Post number 2 is what will fix that.
Here we go.View attachment 119455View attachment 119456View attachment 119455View attachment 119456View attachment 119457View attachment 119456View attachment 119457View attachment 119459View attachment 119460View attachment 119461View attachment 119462
Are you saying put a new shaft in?If your going to replace it or even if your just going to rebuild it just take the driveshaft out and put it in the corner of your garage.
