I have a 2014 JKU Sahara. The previous owner installed Halo LED Headlights of an unknown manufacturer along with anti-flicker dongles.
The drivers side headlight works when cold and then stops when it's been running for a while.
I have swapped headlights (right to left) and ant-flicker dongles, and the issue stays on the drivers side.
The strange thing is that the halo function requires a separate power feed, but when the headlight has the problem it affects the headlight (low and high beam) AND the halo.
I'm struggling to think of a common component that would cause this.
Thanks for any assistance!
Jeremy
Jeremy
