Drivers door does not shut off radio or dash when open
08 jku
Las vegas
Having issues with driver side door,window electrical is fine but when I open the door it does not shut off radio or dash.ive checked the connection ,looks like there's alittle bit of corrosion on some of the pins. The fuses are good,just wondering if anyone else has experienced this issue.gonna clean up the pins but is there some else I should be checking.
It's got to be something to do with the connection. Are the pins corroded, bent, or covered with mud, debris, etc?
Currently having this same problem, limit strap on door broken, door opened too far and pulled wires, wires go to the door latch, haven't got that far yet, this weekend is a good bet I'll get to it
Having same problem with 2018 JK, plus all the doors randomly don't lock the catch up so when you shut it it just clangs. Anybody find the solution?
