Do I need to spend the money on a chip? Will it help my situation?
10-4 just make sure u have a high limit Visa card and a good set of tools 🍺🍺
/whistles innocently
I do ok. ;)
Your transmission is spinning faster. Which means more friction. Which means more heat. Which means more wear. It's not a huge difference, but it IS wearing things faster.
This should help.
All wheel spacers are bad. The thicker the spacer, the worse the are. But they are always a suboptimal choice. The correct solution is wheels with the proper backspacing and offset.
If I re- gear, will this keep the transmission from spinning so much faster and wearing
