Dash lights
North Carolina
My abs and traction control light are on and won’t go off I have replaced the sensors and the fuses and I have tried to reset battery more then once and I have done the steering wheel to the left/right multiple times as well
You need to scan for codes. If you didn’t strongly suggest using OEM parts. Is the steering wheel centered? If not that can cause those lights to come on.
