Dana 30 3.73 front axle housing
Cj7
Michigan
Wrangler JK dana 30 3.73 front axle. I have a small leak in my front axle. My mechanic says there’s a small fracture in the axle. If I order a brand new axle its 4k. Any ideas or websites you guys know about to get a used axle or something cheaper than a brand new stock??? Please help guys🙏🏻
You'll find D30 JK takeoffs all over CL and FB. Usually pretty cheap.
I'd find a reasonably priced one and it should be a bolt on replacement.
Me personally I'd pull it apart, replace the inner axle seals and hubs and inspect and clean everything.
Gotta watch for bent axles too.
-Mac
Do you do any offroading or have 35" tires or larger? If so you might as well upgrade to a D44 front axle.
Have him show you where the leak is so you can give us a picture of the leak.
Reactions: JeepJeezy
If you end up needing a replacement, start with salvage yards. D30's are relatively cheap. Most people want the stronger D44 or D60. And honestly, if you're replacing one anyway, it's a good time to upgrade.
