Cranks-no-start after battery drain
Marty123
Sweden
The other day the battery light on my JK 2011 3.8 came on while on the highway. I tried to push on home but after 10 mins all hell broke loose. All lights startred blinking and 10 secs later the engine died and I pulled to the side. Had to order tow service to parking lot. Then from there my friend helped me flat tow to my home. I'm guessing alternator failure but haven't gotten to that yet since the engine wont start efter new battery (the old one needed changing anyway)
Some facts:
- cranks healthy but no start
- no spark
- no power to ignition coil (it seems - but maybe when cranking - can't check)
- no codes. either with ODB2 or manual check
- ODB2 presents VIN so communicates with PCM
- OD/off light is lit and can't be turned off with button
- ESP light is lit (skidding car symbol)
- grounds are ok (the ones I could find/get to)
- checked all fuses, they look good
- switched around relays - no effect
- I can hear whirring 2-3 secs when connecting battery - fuel pumps ok?
- removed and opened PCM. Doesnt look burned or faulty to the eye
- all electricity seem to be working inside car, gauges working
- fuel in tank
- tried starting in P and in N, no difference
Please advice :-)
The Factory battery clamps are know to be junk, replace them with HD ones.
Do you have 12v's now at the new battery? Check to see if you also have 12v's at the starter on the battery cable.
Thank you for answer. The engine cranks real healthy so seems starter is getting power. New battery, shows 12.5 when newly charged. Clamps and harness looks good, no corrosion, no visual wear on cables. (Difficult for me to measure anything while cranking since working alone at the moment...).
Update. Problem persists. Done since last post:
- Checked ground G104, up top and down below behind heat shield. Rusty down there but no change after cleaning.
- Double checked with spark checker on spark plugs cables while wife turning key and motor cranking = No spark.
Should I take some measurments over fuses/TIPM? if so which ones/where? - while cranking (or not)?
Reactions: Wranglerfix
You sound like, you know what you're doing more than I do, but I chased a similar problem on my 2012 for hours. And hours, I was convinced that the fuel pump worked. But then, when I went back and rechecked the fuses, I found I had a 20 amp fuse that was blown even though it looked like it was in good shape.
My suggestion is go back and check your fuses
Exchanged all M-fuses for new ones now. Problem persists. thx
Some facts:
- no spark
- fuel in tank
Please advice :-)
"O/D off" light now cleared (button was jammed. had nothing to do with main problem - which persists))
Added extra ground cable between battery negative and alternator mount so can rule out ground problem as cause (?). problem persists.
Big update! Engine fires and runs after I jump ASD relay and Fuel pump relay. I measured battery voltage when running and it was same as not running (low), so alternator probably broke.
Also, got a Bluteooth ODB2 and the app Jscan so now have complete fault codes. Codes of interest:
#U0401 implausible data received from ecm/pcm ""a historical
#P0688 asd/main sense circuit ' active
#P0522 engine oil pressure sensor/switch ""a"" low active
#P0562 battery/system voltage low permanent
#P0123 throttle position sensor 1 circuit high, tps/app circuit high, permanent
What next?
Installed new alternator today. Engine fires up as before with the jumped ASD relay and jumped fuel pump relay. BUT. Does not charge even with new alternator. Voltage still 11.7 over battery poles with engine running. What now?
I hate to say it, but it sounds VERY much like the same issues I had in my LJ when the ECM went out. Since the ECM controls the ASD and fuel relay function, as well as charging circuit, all fingers are pointing in that direction.
@Wranglerfix may be of some assistance here...
The voltage regulator is inside your ecm and could be the issue.
Thank you. I did get the Alternator to charge when feeding one of the control fields 12v straight from battery+. Seems PCM dont want to engage the Alternator... Checked the cables from PCM to Alternator most of the way (didnt want to open up the harness completely), they look good. I guess I could go for an external voltage regulator but that wont fix the problem with the PCM activating/(inactivating?) the ASD relay. (Dont like to keep these runaround fixes permanently...just for diagnosis)
More updates:
- alternator charges battery when bypassing voltage regulator
- checked fusible link. It is OK.
- checked grounds to PCM, looks good. ground measures good to hull of PCM (dont know which ground pins to measure to though.., next step?)
- most codes cleared.
Following codes are still active/pemanent:
#P0688 asd/main sense circuit active
#C1502, #C1501, #C1503, #C1504 tire pressure sensor 4 internal active, warning requested
(if you want the "historical" codes still listed by odb2 let me know)
Q: Should I remove the upper intake manifold to check for damaged wiring under there? I can see that the outer plastic on the harness that disappears in there next to the throttle body looks chafed... could something like that be the cause for my symptoms...
Any ideas what to do next?
Marty123, did you ever resolve your issue? I recently bought a 2011 JK. It abruptly lost ignition while on a washboard dirt road. I figured something rattled loose. I have not tracked anything down to solve the issue. It turns over but has no ignition. The spark plugs were terrible, more than likely the original plugs. So I replaced them along with the plug wires. Still no spark. I replaced the crankshaft position sensor. Still no spark. Do you have any suggestions?
My problem is very much active. Worked some on The Beast this morning - verified continuity between alternator control fields to PCM connector (was good). Not in a position to help really (yet :)).
I feel my eyes are drawn more and more to the PCM...but maybe to early to buy new one...
Another Q to the forum: Since my engine runs fine when bypassing ASD and Fuel Pump relays, does it follow that my Crank and Cam sensors are good therefore?
Reactions: Artisanau
Hi Marty123, I believe with a low cost oscilloscope you'll be able to check the switch cycle circuit on/off from the PCM to the Alternator for a positive diagnosis, but reading the descriptive content of your post, I'm guessing you may already be onto it and a successful fix.
Let me know anyway. It was one of the better reads. 👊
Reactions: Marty123
Thanks for tip Artisanau 👌, will look for an oscilloscope to learn more of what exactly the PCM is communicating to the alternator.
Marty123, so I finally figured out that we had a direct short on the harness that runs behind the engine and firewall. The clip that secures the harness to the firewall has broken allowing the harness to shift and rest on top of the back valve cover stud. Over time it had rubbed a hole in the wire loom wrap and eventually the wire. I've resecured it up and away from the contact point. It's currently running. If it gives me anymore trouble down the road it's going to be a job repairing the wire!
Now that I think of this it's a common problem with some of the Jeeps, a few others have had the same issue.
Great find! thx for sharing. I will have to look more carefully back there and perhaps under the intake manifold as well... Hopefully something similar is the cause of my problems as well.
