Snowbird Tom JK Enthusiast Supporting Member Joined Mar 19, 2023 Messages 452 Location Michigan Aug 29, 2024 #1 It’s water pump and radiator replacement time. Looking at the Denso rad from Rock Auto. Anybody with experience using one? Mopar water pump for sure.
Cimmerian JK Enthusiast Lifetime Supporting Member Joined Jun 18, 2024 Messages 373 Location NM Aug 29, 2024 #2 Stick with OEM for the radiator, man. I've yet to hear of an aftermarket JK radiator being better than OEM. Reactions: tJKrider
tJKrider JK Enthusiast Supporting Member Joined Oct 20, 2023 Messages 836 Location SE Michigan Aug 30, 2024 #3 Snowbird Tom said: It’s water pump and radiator replacement time. Looking at the Denso rad from Rock Auto. Anybody with experience using one? Mopar water pump for sure. Click to expand... Are you having an issue or just taking preventative measures based on age/mileage? Reactions: BLACKJKU
Snowbird Tom JK Enthusiast Supporting Member Joined Mar 19, 2023 Messages 452 Location Michigan Aug 30, 2024 #4 tJKrider said: Are you having an issue or just taking preventative measures based on age/mileage? Click to expand... Pinhole leak and coolant oozing from weephole on the water pump. Stuff happens. It's only 8 years old though. Cimmerian said: Stick with OEM for the radiator, man. I've yet to hear of an aftermarket JK radiator being better than OEM. Click to expand... I'm ok with just as good as for 1/3 the cost! Denso is an OEM supplier. Reactions: Cimmerian and tJKrider
