Cold weather issues with radio
Sarahbear73
Ohio
Hi there Happy Saturday All, I am having a problem with my radio having a delay when the weather is 32 degrees and lower and my screen freezing and gets warm. I have had it to the dealer since 2019 and they haven't been able to fix it, I mentioned something to them about a soder or a wire maybe being bare and now I can't get any help to fix this. They are now sayin I am now out of my Mopar Warranty and no help from Stellantis. I have had 4 different case numbers and I have now had my radio replaced 3 times. Can anyone point me in the right direction. I already contacted the BBB no help there :(
Thanks Sarah
Try playing David Johansen's "Hot, Hot, Hot" and see if that helps.
jk... I don't know that I've ever heard of this before but I can almost guarantee it's not a cold solder or bare wire. So, based on the fact the head unit has been replaced 3 times, that it's definitely not the problem. If you could further describe or explain the "delay" and the screen "freezing," that may help.
Have you ever had any issues with cruise control or airbag lights? Asking because I was thinking it could be the clock spring.
Thanks Sarah
Again, you own a JL. It would be more of your benefit to find a JL forum ;)
Do JL's have TIPM's? If so, try warming the TIPM with a hair dryer or heat gun (carefully) before starting or before you normally have this problem. The outside temps are usually lower than the inside. Or, you could put a small space heater in the cab and run it for an hour or so before you start it. Isolating the problem will help you zero in on it.
A solid fix would be to not live in weather like that. too cold for me.
Bundle Up A Christmas Story GIF
Hi Sarah, sorry for all your hassle, it sounds super frustrating. Since the problem comes back even after several replacements, I really think it's a wiring or ground problem somewhere. Maybe a good independent auto electrician would find what the dealer doesn't see. Cheer up, you've already been super patient!
