Cold Air up through center Console/E-Brake
Rich1961
Spring Creek Nevada
My 2016 JKUR has a lot of cold air coming through the center console area behind the shift lever and comes out below the E-Brake lever. Is there a seal under there that has maybe failed? Trying to figure out where to start checking before removing the console. Right now I have some rags stuffed between the carpet and the console to help stop the flow of air, but with 10-20 degree air under there it only helps a little.
Thanks,
Rich
