Climate control light bulb change
Tadeo77
Dubai
Hello, I need to replace some of the lights in my climate control dash for my JK 2009. If it is possible, replace the old ones for led.
I took the central dash but I cannot open the climate control unit to identify the bulbs.
I appreciate your help
Thank you for your answer, but that is an older model. I have been searching a lot and there is only one post in youtube but only asking how to do it.
Post a pic of your climate control panel. I'll be able to help you once I see which one you have.
2009
Dubai? And a 2009 Jk? Is that allowed? Don't the Coppers pilot around in F1 ready vehicles?
The bulbs are soldered in. If you have a soldering iron you can replace them. You have to get 2 skinny flat screwdrivers to pop the knobs off. Then turn the housing over and you'll see 4 clips. Carefully pop them off the white plastic. Once the black cover is off, you'll see the 4 bulbs. I think there are 2 different sizes if I remember correctly.
Thank you for your reply. Actually, I was afraid of pulling the knobs because I though I can damage the plastic. I though maybe you have to put them in an specific position before pull them out. I will try and I will share the results.
Reactions: mrjp and BigAL07
