automatic
thank you i will try thatSounds exactly like the issue I was having that drove me bat sh@@ crazy. Took BLACKJKU’s advice and replaced the bushing on the tranny cable underneath. Then pulled the consol and replaced the bushing on that end at the shifter. Made a very slight adjustment to the cable at the nut and BAM! It has never happened again. You can get the bushings at autozone. On the help rack.
Common for my automatic as well.Have you tried moving the shifter while trying to start or putting it in neutral?
Did you look under the Jeep at the shifter cable to check the bushings to see if they are bad?
