2014 Jeep Wrangler (JKU) Rubicon. Problem started with the P0365 and P0369 codes coming up. Jeep continued to run fine until it didn’t. Now stuck in the ”limp” mode. I was going to replace the camshaft sensors but took a few minutes to test the wiring before replacing the sensors. On both the driver and passenger side I get 5v from pins 1 and 4 but no voltage from pin 2 on either side. Could this be related to a fuse? If so which fuse? Where does the wiring go and how can I further diagnose the wiring as the problem versus a fuse or something else?
