Ryder New Member Joined Jan 31, 2022 Messages 13 Location Valley, WA Apr 2, 2022 #21 Update: rotated the tires and raised the air pressure to 40 PSI. The problem went away…..??? E load range tires. Reactions: mrjp
BLACKJKU Moderator Staff Member Lifetime Supporting Member Joined Feb 22, 2020 Messages 5,390 Location Huntington In Apr 3, 2022 #22 That's the thing about tires you have to experiment on tire pressures to find the best ride. Reactions: mrjp
M Memikesoftball New Member Joined May 28, 2022 Messages 1 Location Texas May 28, 2022 #23 Ryder said: Thanks, the shop said there are a no adjustments possible unless I installed an offset ball joint to correct camber. I have been misinformed before by shops so thought to do some checking with folks that know heck of a lot more than I… Click to expand... Just had my done the shop install a shim kit to adjust mine do to factory set up have a 3 in left
