C123F steering angle sensor after track bar bushing change
RubiRecon
North Idaho
Went for a test drive after changing front and back track bar bushings, now code C123F and steering wheel off to the right to maintain straight driving. Would veer to right with steering wheel level. Well not reset. Everything was fine before. Just trying to refresh things. 59K on 2017 Rubi Recon stock. Code reader says C123F steering angle sensor. How to fix? Cleared code could not reset DTC. Adjusted steering wheel position no help. thanks
I second that. Any time you start replacing parts and tinkering with the front end, odds are you'll need to get it straightened out when everything is said and done.
