Brand new Jeep owner with aftermarket LED headlight issues
I could have saved $200 on a Superchips.... Does it change more settings than a FlashCal?
I don’t have a flashcal to compare. I was literally buying one, in my cart. Until I found this. The app is free to download. You can move around in demo mode and look at all the things and settings you can adjust.
Does your Jeep have daytime running lights on? After doing the lift on the wife’s jku. I bought the programmer to adjust the speedometer an realized I could turn on daytime running lights with low beams or high beams. With her new led headlights and daytime running lights set up for high beams was causing her some issues With on coming traffic. So reprogrammed the DTL to be off. I was able to program her factory driving or fog lights to be on when she turns her brights on. So it floods the area in front of her Jeep when high beams are used. Don’t know if this will he
I just bought a Veepeak OBD check BLE+bluetooth scanner and downloaded the OBD JScan app to fix the light issue on my 2018 Jeep Wrangler JK. Where do I go to shut off the daytime running lights as I have narrowed it down to that being the issue with my aftermarket lights? Also, I would also like to know how to reprogram the tire size as well if that is possible with this scanner?
Plus your dongle into the OBDII port. Turn the key to RUN but do not start the engine. Open JScan. Tap JK. and connect to your vehicle. Tap Adaptation. Tap DRL and follow the on-screen directions.
Same as above, but tap Tire & Axle Settings instead of DRL.
