The fenders, or the flares? Personally, I think it would look dorky without the fenders.The owner of the Jeep took the fenders off to make it look tough.
So you need to drop it 3". You won't get that by going from 37" to 33" tires. Yes, they're 4" smaller, but only half of that is below the axle, so you will only lower the bumper by 2". And the is based on the unlikely assumption that the tire sizes are accurate.Ride height is no more than 24 inches to the bottom of the from bumper. I’m at 27
On the other hand, I did some googling and found this:
Missouri
Bumpers must be at least 4.5 inches tall. Vehicles under 4,501 GVWR have a max bumper height of 24 inches in the front, and 26 inches in the back. Vehicles with a GVWR from 4,501 to 7,500 have a max bumper height of 27 inches in the front, and 29 inches in the back.
The JK Wrangler has a curb weight in the under-4501 range, but GVWR is not curb weight. The GCWR includes the payload capacity. The GVWR for the JK Wrangler is 5400-5700 pounds. Which means your ride height limit is 27" to the bottom of the bumper. Which means you're legal.
