Anyone know what this is called or have a part number
shudacudawuda
Albuquerque
I'm getting my 2008 sport JK ready to send to my son starting college, dug into the door to fix a locking issue and found this piece is broken. It doesn't appear to be in the exploded views I can find. It doesn't come on the latch presenter, I don't see it with the lock rods... Anyone know what it is called or maybe have a part number??
Thanks
I'm unsure so I asked ChatGPT, here was it's response:
Here’s what I can tell from the photo—a closer look suggests the circled piece is not actually a cable link or latch cable, but rather a flexible rubber or plastic clip/guide that helps route or secure the metal interior handle-to-latch cable next to the actuator/latch assembly.
It appears to be a cable guide or clip that holds the latch cable in place, protecting it from rubbing or snagging against the metal latch housing.
For a 2008 Jeep Wrangler JK (vehicle year and model confirmed), the corresponding interior handle-to-latch cable part numbers are:
If the piece you circled is indeed an OEM cable guide, it likely comes integrated with the latch assembly or is a minor clip not individually cataloged with a standalone part number. These clips don’t always have separate SKUs and are often included when purchasing the full door latch actuator assembly or the inside-handle-to-latch cable kit.
As for a specific part number for just that clip: I couldn’t locate one in the available parts listings or diagrams—it likely isn’t sold separately through Mopar. If you need that clip broken or missing, the most reliable route is to order either:
  • The full cable assembly (e.g. 68014959AA or 68014958AA) which may include the clip, or
  • The latch assembly that integrates the cable and its guide, depending on part availability.
Let me know if you’d like help sourcing the full cable or latch assembly with that clip included!
