Because I was needing to repaint behind the door hinges, I locate out paint color via O'reilly auto parts in PA. The bad part about this is that none of the Maryland location had this paint color. Duplicolor has the color matching paint we needed. I was able to repaint under the tailgate hinges, drivers side rear and passenger side rear doors. I've yet to do the front door hinges. My main interested was to repaint the hinges before I installed the Moreryde tailgate hinge and two brackets for the side doors. light sanding with a scotch brite pad, clean with alcoholic, repaint then clear top coat.
