Alarm / lock issues (alarm keeps beeping without using FOB)
Crymdogdee
Norfolk nebraska
My 2014 Wrangler's alarm keeps beeping and the doors keep locking without me using the fob, all by themselves. If you are inside the vehicle when they lock, the auto unlock will not work and you have to manually pull the lock to unlock the car. I keep getting locked out or locked in. I changed battery in fob. Any ideas on how to correct?
Could be the contacts under the rubber buttons. I had to buy a replacement key cause of this. You sometimes can find just the rubber part with the contacts on amazon
I have this problem with a key that got washed, do you have the same problem with both keys or just one? If it’s just one it’s probably key related, if both the problem might be elsewhere.
