Adjustable control arms
jeeperscreapers
nova scotia, canada
lifting my 2010 2 dr jk (2.5") and getting all pieces a bit at a time and trying to educate myself at the same time....was looking into 8 adjustable control arms, but do i really need 8, could 4 adjustable and 4 solid ones get me the proper angles for alignment....btw, i would not know which 4 should be adjustable if i can go this route..thanking you all in advance....
You're certainly welcome to spend the money on adjustable control arms, but as Black stated, unless you go beyond 2.5", they aren't necessary. I have a 2.5" lift and don't have them. Matter of fact my front track bar is adjustable, but the rear isn't.....hmmmm.... maybe I should look into that.
Nonetheless, you will probably need that money at some point in the future. It is, after all, a Jeep.
Same here, have a 2.5” lift on 3 JK’s and no problems without the adjustable LCA’s.
