5 quarts of oil?
serendipity2525
AZ
I changed the oil in a 2016 Rubicon with the 3.6 V6. When I filled with oil and warming it up it was showing full with only 5 quarts. The owners manual says it takes 6. What are your thoughts on this? I wondered if the dip stick was not the one that belongs in this engine.
Did you check before or after you started it? The new filter will will hold some oil so need to start her up for a couple if minutes then let it sit for a couple of minutes and recheck it.
Reactions: mrjp and tJKrider
