4WD light flickering and loss of power while driving
Altitude22
Michigan
Anyone have the 4wd light flicker and lose power while driving? I cycled through 4 hi lo as I seen that might help in a different forum and wondering if it’s the sensor on top of the transfer case. Not much on it that I found thanks for the help
what was the problem with the transmission? I am having this issue and getting c1404, u0414 codes. I think it could be a transmission issue but not sure. Thanks
Can you tell me if you resolved this? I swapped to a rubicon transfer case and it was perfect the first time I took it out. Now the 4wd light flickers in 4hi and the jeep stutters and de-fuels.
I’m fighting with this after a rubicon transfer case swap. Could you please tell me more about what went wrong with yours? Mine was perfectly fine before the t-case swap and works fine in 4low, and 2hi. But can’t get 4hi to work right. It just sputters out and the dash light flickers. This is literally the only thread I’ve found online with the same symptoms.
I only changed the battery when it went dead and now I’m having the flickering and seems like it’s going into 4low while driving at speed. Kind of scary… let me know if anyone has the same issues
What year is your Jeep, I thought all of them the only way to get into 4 low was to manually shift the Transfercase shifter.
