35's tires with 15 inch wheels stick out too much
Frankie
New Jersey
Good afternoon. I own a 2013 jeep wrangler Sahara unlimited. I'm running
LT35X12.5R-15 GENERAL GRABBER A/TX C
With American Racing Baja, 15x10 Wheel with 5 on 127 Bolt Pattern.
My issue is my tires stick out way too much with these wheels. I'm trying to figure out what 15 inch wheels would fit better so that my tires don't stick out so much.
Advise will be greatly appreciated it. Thanks
The "normal" wheel for 35's has 4.25 or 4.5" of backspacing. You may find that 15" wheels hit your brake rotors if you move them inboard.
What @Dirty Dog said. Without grinding your calipers down, 15" wheels won't work to move them inward. Maybe try and pull a wheel off, flip it around and try to slide it on and see what it hits. Maybe you won't have to grind much off?
Reactions: tJKrider
