First time writer long time reader. The other day my wife's jeep through a misfire code for cylinder #5. So I started by changing the spark plugs. I bought some cheap spark plugs because the part store did not have any of the  recommended spark plugs available (which are champions) I replaced 1,3 & 5 because i was in a parking lot. Misfire still there. Got it home and bought 6 new champion spark plugs and replace all 6 of the and the misfire still there. I went ahead and replaced coil packs on all 6 cylinder and the misfire is still there. I tested the fuel injectors 2 of them tested bad compared to the other 4. On cylinder 2 it ohmed out to .21 and on cylinder 6 it ohmed out to .002 while the other 4 injectors ohmed out to .142 . I went ahead and replaced all 6 injectors. Guess what cylinder # 5 misfire is still there and yes you can feel the misfire. I took the valve covers off to check out the rocker arms and to make sure none of the intake or exhaust valves where stuck. All of that looked great no broken springs and all the rockers are in place. Ive looked up multiple possibilities and I'm stuck. So that's why I'm here and if anyone can give me some other direction to head I would be greatly appreciative. Oh I also have 4 new 02 sensors imma try when I get a chance. Thanks
