Hello,
Our jeep started having a strange problem seemingly out of the blue.
It randomly seems to die (engine shuts off) while driving.
I haven't been able to 'force' it to happen.
It has happened while driving AND while sitting at a light.
While driving, the initial symptom is that it shifts strange (like kind of a hiccup), then it dies. But when sitting at a light this obviously isn't the same.
I can put it in N and restart it while coasting.
It doesn't throw any codes
It doesn't seem to be related to:
Accelerating heavy
Coasting
Hitting bumps
shaking or wiggling the keys in the ignition
Its a 2016 Sahara 4 door with 35" tires, the retracting rock rails, stock stereo, AC works. 85k miles.
I have tried driving hard (getting RPMs up) then shifting to N to see if the engine doesn't 'catch' idle, but the time time I tried it no issue.
The only thing I have found is the Air intake temp sensor has the clip broken off, so could be loose? Not sure this would cause this issue.
Thoughts?
Thanks a bunch
Dave
Accelerating heavy
Coasting
Hitting bumps
Thoughts?
Thanks a bunch
Dave
