2015 Rubicon - Oil Leak
Georgia_Dirt
Pooler, GA.
I have a minor oil leak and can not determine where it is coming from. Appears to be from the front of the upper oil pan or the front of the engine. Has anyone experienced this or have any advice? TIA
Some people will get a dye you put in the oil and then you check it with UV glasses to see where the trail is.
I would check the oil cooler. Super easy to see if it is the problem. Take a flashlight and look down at the top of the block near the oil filter (which is connected to this part) There are vids online about this. There is a certain place to look that allows you to see if oil is pooling there or not. After this area fills up it drips off the top of the block. It's something that happens to these engines.
Easy thing to eliminate if it's not the problem.
