Was driving my 2015 Rubicon and went to get my battery replaced as it was getting pretty weak. When I got there and popped my hood I noticed it was pretty dang hot under the hood. I looked at my temp gauge and it was pointed straight up in the normal area. Coolant was a hair above the max line but that may be my fault as I may have overfilled it a while back. I clicked through the menu and got the electronic temperature and at idle it was 204 with AC on. When I drove home the temperature moved between 215 and 224 with the AC on. This was on a 78 degree afternoon.
Does this seem high? I did a search but couldn’t really find a definitive answer on where these 3.6s run temperature wise.
Also....does the electric fan come on at 225 degrees? Is there a way to test the fan to ensure it’s working properly.
Thanks for any info and advice.
