I've run into some trouble in my 13 Wrangler where it slipped out of gear, then shortly afterward refuses to go into any gear forward or reverse at all. Its behaving as if it's in neutral. Its a NAG1 transmission. Its not the shift linkage, that's secure, not fluid - levels are good. I did find historical codes: P0732 and P2784, which made me suspect sensors, so the contact plate has been replaced. Fluid is clear, no debris in pan, filter is seated. Wiring appears to be in good condition.
The torque converter was just replaced, by me - went in fine, and car was driving nicely with no issues till now.
It's got me stumped, the only thing i'm hanging onto at the moment is that since it will not go into gear, the fluid appears to be high, but I can't get it into neutral, which would be needed to engage the pump and have a realistic fluid level to test.
Perhaps the pump is not engaging?
I do have a scanner and can pull live information from the transmission. Does anyone have suggestions on where I might start to troubleshoot this further?
Cheers, mark
Cheers, mark
