I have an intermittent no-crank issue that I have not seen a forum discussion thread discuss. Very intermittently, my 2012 Wrangler will not crank-over and is completely dead. Sometimes it seems to be associated with heat buildup, such as on a hot day after stopping it. At other times, it has happened when 4-wheeling and I've done an ascending climb and stall it with my manual transmission. After other times, it is from a cold start in my garage. It does seem to occur more in warm outdoor temperatures rather than cold outdoor temperatures. In most cases, I can restart it eventually after a few minutes or if I move the vehicle a bit forward or backward. In any case it is unnerving when it happens while 4-wheeling in remote locations. The occurrence is very intermittent and occurs about once every couple of months. My battery has been replaced and my battery cables/connections all look in decent condition. Thoughts out there?
Mystery in Colorado...
