• Looking for parts for your Jeep Wrangler JK? Checkout the selection of JK parts Amazon has to offer, many with 2-day Prime shipping!
2012 Jeep JK 3rd Brake Light
IronHelmet
Boston
So while installing the Teraflex tire mounting kit, my 3rd brake light went dead. Tried stock light as well as an aftermarket light…neither worked. Thinking about replacing fuse as next step. 3 questions:
1. What is location of fuse?
2. What kind of fuse do I buy?
3. Is there anything else I should try to fix?
mrjp
Ride of the Month Winner
Southern Nevada
Try following the 3rd brake light wiring and the connection or plug maybe in the tailgate.
MacGuyver
Wisconsin
Yep, sounds to me like you either unplugged or severed the line going back to the tailgate. First thing to check is if the key fob unlocks/ locks the gate still. If not, cut wire (probably) if it does, look around the light for the plug. (though it could still be a partially cut wire)
shipjim1
Texas
Access is behind the vent near the rear handle. It's a plug and play. As others have said check all the wiring especially between the plug and the light.
