- Price
- $95k
- Location
- Wellington NV
It's a long list so sit back and get ready..
Time for a change so it's up for sale. $95k
2011 Jeep Wrangler Unlimited Rubicon. Currant miles 45800
2012 tapshift shifter
Cruise control
Auto AC
Pentastar fan
Big Motech radiator
Custom AL over flow tank
Mocan custom kit by JOHN SCHUMACHER OVERLAND PERFORMANCE
Fully loaded Rubicon with every option other than leather, hard top, 730N Media Center, power everything.
AEV vented Hood
2012 Lc9 motor and 6L80e trans had 840 miles on them when bought and modded.
Motor has Comp can, LS7 lifters, valve springs etc.
DOD deleted, VVT Comp cam with phase limiter.
Custom tuned engine and trans.
6l80 4x4 Trans
Both out of a 2012 tahoe with 840 miles, approx 4800 since build.
R2C Performance Products custom air filter.
Approx 420HP at crank.
Engine custom tuned by Real Performance Speed in Sparks NV
Runs on Reg or Premium
Trans custom tuned by Zero Gravity Mesa AZ
Atlas 2sp 3.8 HD 300m outputs Flat capable with cable shifters.170 miles since install.
Jeep towing harness installed.
Custom built XD60 with f450 brakes, Pro Steers, Dynalocks etc/ PR80 5.38's and ARB's
Rear PR80 5.38s arb's
All Vented to roll over filtered valves
5ea 40" Nitto Trail Grapplers on Chamber Pro's custom Powder coated Beadlocks or 5ea new 39" BFG KM3's on new Walker Evans beadlocks, byers choice.
Suspension is all custom:
7075 AL long arm 3 link front.
SAW 14" 2.5" C/O's 14" 3 tube Bypass shocks. TG Limit straps.
RK Pro Joints
Rear Triangulated cromo uppers with Heims.
Triangulated Lowers cromo fabbed heat treated trailing arms with Heims and Delrin bushings..
12" SAW 2.5" C/O's and 14" 3 tube Bypass shocks.
2" rear King Bump stops.
All brackets 1/4", most fab parts A100 3/16 steel or Chromoly.
15" front travel 18" rear unstraped.
Shocks modded and custom tuned by Phil Licciardi@ Liberty Mountain Fab.
TK1 Racing front, rear Currie sway bar.
PSC steering box, ram, Rez and cooler.
7075 custom tie rod, Currie HD drag link, RK track bar.
Genright 20 gal Aluminum tank and steel skid plate.
Custom 3/16 plate full skid plates.
Expedition One front bumper with Warn 9.5 CTIS winch and FACTOR 55 WINCH LOCK BOLT and Shackle mount.
Poison Spyder Customs rear bumper (brawler series with swing out rear tire carrier)
Poison Spyder Interior Trail Cage
Hard Rock harness bar
Poison Spyder Brawler Rockers
Rigid Dual Rear back up lights
Boom mat sound insulator in Hard top, inside top painted black.
Complete interior is Dynomat covered.
Adams frt 1350 cv , rear is a custom by B&W driveline 1350 cv/1410
Custom stacked plate trans cooler all ran with SS and AN fittings
Carrichs ipad or android holder
Designs 67 carbon fiber mounting system for Kenwood TM-V71A head and traildash. TM-V71A body and Anytone CB mounted overhead.
Crow 4 point harness plus stock JK belts
ARB compressor mounted behind passenger tail light
Magnaflow 2.5" 400 cfm flow Cats. all 2.5" 304SS with 2ea BORLA mufflers tied to 3" out on passenger side 4" Magnaflow muffler. All wrapped with Heatsheild muffler wrap. Underbody covered with Heatsheild 2000* stick on.
Bushwacker flat flares
Huskyliner floor mats and cargo area mat
Mopar fuel door and door sill protectors
Full rear Springtail Solutions Molle storage panels with compartments for Battery, 5gal Fuel and 2.5gal water, shovel, axe, Co2 tank plus Molle bags.
Flat floor from rear to front seats with storage under area where 2nd row seat footwell is.
Sealed 7 Hid Headlights.
2ea Hids with Amber covers
1ea 20" dual pattern LED
Spod with lighted switches.
2ea Hawker Odyssey batteries with Painless dual battery system
All ran with 1AGW welding cable and Military spec connectors.
All glass quartz tinted dark.
Engine, drivetrain, all suspension has approx 4800 miles since built.
Much More not listed.............
Thanks for looking, price is negotiable.
Cruise control
Auto AC
Pentastar fan
Big Motech radiator
AEV vented Hood
6l80 4x4 Trans
RK Pro Joints
