Hello,
I’ve stalked the forum for years now and hoping you guys can point me in the right direction
I have a 2011 Jeep Wrangler 6 speed and the other day I parked it, went back out to start it and crank and no start. My first thought was fuel pump because I had installed a Motobilt tank about a year back and figured something was up. Tested with a battery straight to the pump and it kicked on. Ran Jscan to see the codes and nothing came up.
Next started checking the TIPM because I read though the forum it was a common issue. Jumped the m25 fuse to the m7 fuse to see if I could get the fuel pump to kick on, nothing.
Checked with my multimeter, I’m getting power to the m25 when keyed on and I’m getting power to the fuel pump plug at the first and last pin on the connector, which from what I’ve read should be positive and ground for the pump
Threw a cam sensor at it just to see if what would help, nothing
Cleaned and checked grounds tonight to see if it was just a bad ground, no luck there either
Last thing on my list is the crank shaft sensor, I pulled mine and checked for continuity, everything seemed alright but I’m going to test a new one out tomorrow.
Not sure what else is left to check, any help is greatly appreciated, will keep you guys updated if I find anything else
