I am new to the group, just purchased a 2010 Jeep Wrangler Unlimited Sport JK. It is currently completely bone stock and only has 61k original miles. I am looking to add some flare to it. Usage: Mainly general use and up and down some gravel roads. Will not be used to rock climb or anything super extreme. I would like to give it a little lift = Maybe 2-3 inches and maybe slightly upsize the tires and give it a slightly wider stance. I would also like to avoid a significant loss of power or needing to change gears. What would be recommended, two or three inch lift ? What size tire / wheel combination should I try to stay with. I was going to try to stay with a 17 or 18 inch wheel. I would like to not completely fill the wheel opening with tire and wheel. I would like for there to be some clearance there. Thanks in advance.
