So I replaced the bank 1 sensor 1 o2 sensor because it through a code p0032. After it was replaced by mechanic it through the code again. It was verified that the o2 was good using his reader (Zurich z13). Has this happened to anyone else did it turn out to be the ecu, is there something else I should look for. I used an NTK o2 replacement sensor. Is there a better one?
Any help is appreciated.
Thanks Tony..
Thanks Tony..
