2008 3.8 throttle enhancer: which is best?
Who uses one and which one is the best.
Dollar wise and responsive wise?
They're all basically garbage and every car I've driven with one installed essentially feels just like stock with a marginally different throttle response curve. Personally, a 1:1 ratio is the most logical for 99.9% of driving and is easy to predict. Unfortunately, in the age of "lazy transmission" programming (under the guise of "fuel economy"), poor gearing ratios, and drive-by-wire, you just need to get used to your shift points and learn to manipulate the throttle accordingly.
In the case of the 3.8L, it's a minivan engine pushing a brick down the road. If you aren't regeared, start there...
Of course he sells his brand so he needs to make his sound better, does he sell his brand for a Jeep?
Yes, of course it's available for Jeeps.
If you watched the whole video, he's not just selling his brand, he's settling a fight that Pedal Commander started with actual evidence of how unsafe they are.
Reactions: John Cooper
Whoever fixed my title, thanks!!!
Stupid phone wouldn't let me edit at work this morning!!!!
I'm not looking for more power, just throttle response.
I do have plans to regear in the future, probably in the next year.
The pedal control modules do little or nothing. If you want to improve throttle response, start with tire size and gear ratio. Or (and nobody will be surprised when I say this) a V8 swap.
Our recent experiences are:
2011 JKUR with 3.8L and 4:10 differential gears and an A4 and 35" tires. It feels sluggish. But it's responsive enough for my wife, so she drives it.
2013 JKUR with 3.6L, a few engine mods (CAI, exhaust, 93 octane tune) up from 285 to 300HP, 4.10 gears and a M6 with 35's. It's marginal, especially on the highway and mountain passes.
a 2023 JLUR with the 392 Hemi with a bit of engine work (mostly a premium tune) making 500HP, 3.73 gears, an A8, and 37's. The math says I'd be better with 4.88 or 5.13 gears, but I don't see that happening unless I eventually go up to 40's. As it sits, it will spin all 4 on a hard launch. More Power!!!!! is the answer to most performance issues.
An automatic? hilarious.
Indeed... there aren't any gear ratios on the market to properly gear the 42RLE, with the exception of stock (or near stock) sized tires. I'm about to rebuild the take-outs from my 2008 (D30/44) and prep them for my daughter's 2010 Islander while she's at school. She'll only ever run 33"s, so I'm going with 5.13's to make overdrive useful and not be so gutless on country roads.
I may just have to Hemi swap hers too lol
I've had my Pedal Commander on my 07, 3.8L manual trans, 35" tires for 5 years. It's been dependable and effective for me.
I initially got it when I had 3.21 gears and it helped to a certain extent. Then I got 4.56 gears and my JKU woke up with the combo of both (I do credit the regearing more, but the Pedal Commander helps tremendously). I usually leave it on Sport. Sport+ is a bit much.
I'd get the PC in a heartbeat again. It helps with throttle response. Although... I've heard the cheaper ones like the Hikeit and others on Amazon have brought luck to others.
Just remember, it's not going to add hp or change your life... but, it has been a game changer for me, especially with the regearing. You DEFINITELY will feel a difference. As far as the Banks video... I'd try the Banks too 😊.
Get one! Even if it is a cheaper Hikeit one from Amazon and upgrade from there. But, if you're not regeared yet... that's the cat's a$$ right there. But, it will cost exponentially more... As in 10-20 times more than a throttle controller.
