Have had the common no start issue for quite a while now. You know the one. Turn the key and get the keep sneeze. Little pressure on the shifter then fires rite up. Added a ground wire from battery to the alternator bracket and seems to cure the issue. The only time I get it now is after a good rain. Little pressure on the shifter then she will either fire rite up or start and die. After that she cranks rite up and runs great. Wandering if anyone may know where I should look to track this down. Thanx in advance for any input
