Wife was out today and while entering the freeway, the Jeep stalled. She was able to get safely to the shoulder and it started up again w/o any visible/known cause.
I suspected the recent fill up might be to blame, but I advised her to come straight home.
Once home, the Jeep idled strangely, from a normal idle to a reduced idle (as low as 400-500RPM) and it would then die.
Could hardly keep it running and it would stall when put into gear.
This made for very slow progress of parking it in the garage.
First thing I did was run JSCAN and check for codes... NOTHING.
It stalled a few more times and then I finally got the CEL.
Code was P0335, which is attributed to the CPS (crank position sensor).
Did a quick review of the R&R, confirmed the part # and stock at my local AutoZone.
$24 and about 20 minutes later, I had the new sensor installed.
Cycled the ignition, cleared all stored codes, and drove it to the car wash.
No issues, it actually seems to run better but that might have just been the weight being lifted off my neck, it's difficult to know for sure.
Anyway, now the code remains as "permanent" in the JSCAN list (which also includes codes for the radio, TPMS, and the headlights - all currently showing as "active").
Is there a way to clear the P0335 code that isn't straight forward/intuitive?
I need to pass a smog check soon and I want to make sure this isn't going to be a pain in the ass for me to clear up/fix.
Also, any other issues that could contribute to this code that I missed?
