I’ve taken my 2016 Jeep Wrangler JK to a few people regarding this “frog noise” and no one can tell me what it is.
This was my thought as well.Possibly a idler pulley bearing
The auto mechanics that I took it into said that they can’t get my Jeep to make the noise long enough to locate. He also said that he checked the idle pulley bearings and they seemed to not be worn out. What else could it be?Possibly a idler pulley bearing
But did he take the belt off? Can't tell if the bearings are bad without taking the belt off.The auto mechanics that I took it into said that they can’t get my Jeep to make the noise long enough to locate. He also said that he checked the idle pulley bearings and they seemed to not be worn out. What else could it be?
I didn’t ask if they took the belt off or not. I just assumed they did? My fault for assuming I guess. Everything is just pointing to an idle pulley bearing so I may just have them all replaced if that’s the case.
