Would 285/70R17 Maxxis Razr 811 tires fit the original wheels?
Ricky Slapz
Miami
I recently picked up a 2017 Rubicon (2 door) it still has the original wheels on it (17's).
Would the 285 70 17 Maxxis Razr 811 fit the original wheel, or am I missing something?
Perfect thanks guys. Any issue with rubbing if they aren't spaced out? I saw a couple of old threads that said their could/would be rubbing off roading with 33's.
Mine will almost exclusively be a DD for the foreseeable (near) future.
Typically guidance is that they may rub slightly at full lock with no lift or spacer. Yours having Rubicon springs maybe you'll be ok..
Reactions: Ricky Slapz
