Help, I am at wit's end. Our 2012 Wrangler Unlimited has a couple problems neither the dealership nor I can seem to fix. Started with the engine dying at a stop or sometimes shortly after start. Almost always restarts right away, sometimes cranks a while. The dealership has added an external fuel pump relay and ran a wire back to the fuel pump. Didn't fix it. I replaced the TIPM, nope didn't fix it.
During this the wipers quit returning to park and delay does not work, runs same as slow. I replaced wiper motor, wiper switch and even the turn signal switch because the wiper switch plug into it. I also cleaned all grounds and ran a wire hooking them all together running back to the battery.
So the engine dies and wipers will not return to park or delay.
Please help!!!!!!!!!!!!
Jamie
Jamie
