Windshield pump works for rear but not front sprayers
Jackmove
Virginia
The windshield pump does not make noise when using the front sprayers. However, the rear works and you can hear the pump working.
There’s washer fluid in the reservoir.
I pulled the hoses from the front nozzles and they don’t work.
I pulled the fuse and it stops the rear. I reseated the fuse. Only the rear sprayer works.
I unplugged the power to the pump and reseated it. Only rear sprayer works.
Pulled the pump out and checked the filter at the bottom and it’s filter is clear.
The arm switch seems to be working. When trying to mist front sprayers the front wipers engage.
All other items on the arms switch work.
Are there two motors for front and rear?
What haven’t I checked?
If the pump is pumping, but it's not flowing, then I'd say something is plugged. If it's not running, then I'd suspect the switch.
