Are you doing this to upgrade to bigger tires? Actually you'll need 6th gear even more if you want to be able to drive in the RPM range your supposed to.
as a note, no matter what the gear ratio a 4 door wrangler is only rated up to 3500 lbs. But yeah. I'm unsure why they ever bothered with 3.21. Probably some fuel economy thing.
